cross over steering question and idea
Discussion in 'OffRoad Design' started by primerk5, Sep 7, 2001.
  1. primerk5
    primerk5 1/2 ton status
    Jan 13, 2001
    220
    Finksburg MD
    look at your 4x4 and awnser me this is it possible to take the tie rod in the front of your axel flip it so that the stock steering shock whole is at the passenger side take a second tie rod bend it to fit between that bolt hole and the 2wd steering box with a ford steering arm would this not be cheeper and would this work
    PRIMERK5
  2. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    You would think this would work...until you tryed it and bent the tie rod from steering effort. The hole where the stabilizer goes is prolly the weakest point, and with the angle of the steering rod coming down it would bend the tie rod in no time flat.
    Rene
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    trusty pretty much spelled it out. I have some jeeper buddies that tried it and bent the ends. Also, you end up with a HUGE angle on the draglink which translates into really lousy steering. another problem with running the draglink into the tierod is the tierod will rock up and down every time you steer it and it give a little less tight feel to the steering. That's the really nice thing about running the crossover draglink into the arm on the knuckle, it is very direct and gives good tight steering.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
