cross over steering question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hoserr, Aug 27, 2001.
  1. hoserr
    hoserr Registered Member
    Jul 25, 2001
    78
    chula vista, ca
    hey amigos, i put cross over steering in the K5, got the modified steering arm an' the pitman arm from Off road designs, very cool, except. it turns farther to the right than to the left. i stuck up on jack stands to figure the problem, lengthed the drag link. wala. fixed. lock to lock smooth as a baby's rump. figuring it was fixed i put on the deck. the same problem i had before i adjusted the drag link. why?
    uh, think it'll fit?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Did you have the steering wheel centered before you adjusted the drag link?
    I have seen where the adjustments were not correct due to the steering wheel not being centered and that made it 'off' and therefore caused the shorter turn to one side.
    Basically, the steering wheel needs to be centered with the pitman arm pointing straight forward. Only on the 2wd boxes. If you have the regular type draglink and steering, then the pitman arm needs to be pointing straight out to the driver side tire.
    Just make sure the pitman arm is pointing in the straight direction and the steering wheel is centered also.
    <font color=blue>"Ya don't have to beat it, ya know!!!</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  3. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    Did you have the jackstands on the frame or the axle? If you had them on the frame then there might of been some suspension droop. It would be best to make the adjustments while the blazer is sitting on the ground. Might be worth looking into.
    Keep it simple!
  4. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    What did your system cost from ORD?
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  5. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    Make sure the small limit travel bolts on the inside of the steering knuckles aren't bottoming out on one side before the other.
  6. hoserr
    Jul 25, 2001
    78
    chula vista, ca
    the steering wheel hasn't even been centered, but the pitman arm is centered the travel on the steering box. the pitman arm was pointing straight, parrell to the frame. if i point it to the tire the drag link won't function correctly.
  7. hoserr
    Jul 25, 2001
    78
    chula vista, ca
    had the jack stands on the axle. okay, i'll give it a shot, on the ground that is.
  8. hoserr
    Jul 25, 2001
    78
    chula vista, ca
    the cost from Off Road Designs was:
    80 bucks fer the pitman arm
    125 for the steering arm
    36 for the conical washers an studs
    shipping i don't recall,
    machine shop time, 4 dozen donuts, 2 cases of beer.
  9. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Which way does the pitman face with the steering wheel centered? It needs to point straight back with the wheel centered.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
