Cross over Steering V/S High Steer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77blazin, Jul 7, 2006.
  1. 77blazin
    77blazin 1 of a kine K5
    Mar 31, 2000
    394
    Honolulu Hawaii
    Sounds like a bunch of cows doesn't it,:haha: Well here goes..
    Got some information on fixing my 78 that has a 6 inch lift, some dumb misfit slamed into my truck putting a big dent on my front passenger rim and bending the knuckle, I was able to save the axle and pull off the knuckle, so I went on ebay and saw this thing called high steer and this weird looking knuckle:
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=8065588133&sspagename=STRK%3AMEWA%3AIT
    That didn't have the tie rod stem on it, would this be a better item for my truck?
    So I kept looking and found this::D
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=8076090973&sspagename=STRK%3AMEWA%3AIT
    Wow!:eek1: interesting, so I looked up this thing called High Steer and noticed you have to to alot of modifications, What mods do I have to do, is it better than the famous cross over steering or will this be the more advance setup for my steering problem.:dunno:
    Mike
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Hi steer is just an addition to regular crossover. It moves the tie rod up above the axle with the draglink. You need a hi steer arm on the driver side. The knuckles in the first auction are just D44 knuckles without the stock tie-rod location. You do not want the arms listed second. They don't have the angle machined into them to account for the angled surface on top of the knuckle. When your suspension moves the rod ends will max out very quickly. Just buy some steering arms from a reputable vendor like Sky, ORD, WFO, or Northwest fab to name a few.
    Side note. Hi-steer puts more stress on the top of the knuckle especially if you plan on hydraulic assist in the future.
    Pic of hi-steer vs standard crossover
    Hi Steer
    Standard crossover
  3. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Like has been said xover is just the draglink changing, high steer is moving the tie rod up with the drag link. both work very well. But both can be done with out buying new knuckles. You need knuckles that are called flattop very easy to figure out if you have them as both knuckles will look the same except one wll have three holes drilled in it and the other will be flat but not have the three holes drilled in it.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Anyone ever have any trouble with this on a non hydro system?
