cross over steering, with tie rod above springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigredblazer, Jun 29, 2001.
  1. bigredblazer
    bigredblazer 1/2 ton status
    May 10, 2001
    170
    western slope
    does anyone run a system like this? I'm planning on doing a crossover conversion soon, and looking for some feed back on running the tie rod above the springs. Has anyone had any problems with this system? Any info will help...Thanks
  2. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    My brother did this on his '85 Toy. He has not had any problems with it.
    If you need any parts check out Avalanche Engineering...
    <A target="_blank" HREF=http://www.avalancheengr.com/parts/steering/high_clearance.htm>http://www.avalancheengr.com/parts/steering/high_clearance.htm</A>
    That's because I'm the devil.
  3. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    here's my set up on a Dana 60 axle
    <A target="_blank" HREF=http://www.tennessee4x4.com/rocketcity/titanic.htm>http://www.tennessee4x4.com/rocketcity/titanic.htm</A>
  4. bigredblazer
    May 10, 2001
    170
    western slope
    Hey Titanic, what kind of pitman arm did you use?
  5. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    titanic,
    did you notice a difference in tight turns with the loss of ackerman?
  6. titanic
    Mar 27, 2000
    498
    I used a Skyjacker brand f-250 4" drop pitman and reamed the hole out so I could use the larger chevy draglink ends. I
    use 3/4 chromemoly national rod ends for the actual tierod
    Snap-on cat. #R-121 is the reamer I used.
  7. titanic
    Mar 27, 2000
    498
    I was told I would notice a difference is tight turns but all I can tell you is I can turn sharper than stock without any bumpsteer what so ever. On a Dana 60 axle -this is the way to go! Steve
