cross over steering
Discussion in 'The Garage' started by jacked_86chevyk10, Feb 22, 2004.
  1. jacked_86chevyk10
    jacked_86chevyk10 Registered Member
    Feb 4, 2004
    42
    SNELLVILLE, GA
    whats the purpose of croos over steering? /forums/images/graemlins/confused.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    stock steering has bad geometry. So when you flex out your suspension (especially droop the drivers tire) your steering angle goes real bad and steering becomes very difficult and most of the time under heavy drivers droop steering to the left becomes almost impossible.
    With crossover the geometry is much better because the tires are now steered off the passenger side knuckle instead of the drivers. Your draglink becomes longer and your angles are greatly reduced which makes steering much easier when you are flexed out. Not as much bind on the steering.
    Harley
  3. jacked_86chevyk10
    Feb 4, 2004
    42
    SNELLVILLE, GA
    who makes cross over kits for a 86 chevy k10? thanks buddy
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Here are a couple /forums/images/graemlins/thumb.gif
    ORD
    Sky
