cross over
Discussion in 'OffRoad Design' started by mccomas, Nov 12, 2005.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    do i have to change my steering box to go cross over. ord's web page shows required items as new pitman, drag link, tie ends and steering arm.
    at that bottom of the web page it also talks about a 2wd steering box...
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    You do not HAVE to change the steering box just swap the sector shaft with one from a 2wd. If you have a 2wd box it is prolly easier to just change boxes.
    Ira
  3. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Here is a picture of the steering box and the sector shaft for you.
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    You do however need to make sure that if you do change only the sector shaft that it is of the same kind....IE: standard ratio steering or variable ratio steering since both the sector shaft and also the rack nut are different between the two.
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We've found that it's typically easier to just swap the box. You have to take the box off to switch them out anyway so bolting up the new one is usually the way. It's good to know that you can swap sectors but it's not always THE answer.
