Crossmeber question.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crazyrc, Apr 19, 2003.
  1. crazyrc
    crazyrc 1/2 ton status
    Jan 20, 2003
    106
    Northern Alberta, Canada
    When I remove my 700R4 and 208 and replace them with a T400 and 205, will I need a different crossmember. I'm not sure on the lengths and mounting points.
    Also is the mounting flange on the front of a 205 the same as a 208. I mean the connection to the front shaft.
  2. crazyrc
    Jan 20, 2003
    106
    Come on guys...I'm sure there are lots of you out there who have done this swap.
  3. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    I did a 250/203->465/205 swap and just used the donor X-member, mounted it all up, then drilled the holes with the xmember sitting on the frame. No need to measure.
    ansdy
  4. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    i went from a 700r4 208 to a 350 205
    all i did was mount to the trans case and
    drill new holes
    no problems yet
