Crossmember and rear trans bolts
Discussion in 'The Garage' started by PROFESSORSK5, Dec 29, 2002.
  1. PROFESSORSK5
    PROFESSORSK5 Registered Member
    Dec 19, 2001
    81
    So California
    I really don't know how all this happened but today as I was going to a friends house to go off roading, my K5 would not go into revearse or park, so I stopped and looked under my truck and the two bolts that hold the crossmember to the frame didn't have nuts on them. This caused the crossmember to sag and if that wasn't bad enough the two bolts that hold the trans tail shaft to the crossmember were also missing. If this is a common thing, please let me know what I can do to fix this, or set up some time table to check these bolts. /forums/images/graemlins/k5.gif
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    it sounds like the tranny's been out and somebody left the bolts loose? I know that the bolts on the tranny mount will come loose if no loc-tite is used. they will vibrate loose. never seen crossmember bolts come out though!
  3. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    that happened to me too a while ago on my 78 k20 no explanation.. the tcase was being held up by the rear driveshaft and the support from tranny/motor.. /forums/images/graemlins/eek.gif
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I used to break the stupid crossmember bolts on the passenger side. I ended up putting in Grade 8 bolts to fix it. I even considered putting that side of the crossmember up into the frame.
