Crossmember fab
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieRed, Mar 2, 2004.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    ok. . . so i got front shaft issues. and got a few possibilities
    a) clearance the xmember and weld some plate to bottom of xmember to retain strength
    b) clearance/cutout part of xmember and weld in behing cut to retain strength (seem unlikely i'll retain stock strength)
    c) make new x member completely
    d) get a taller tranny mount- might have to fab that
    any ideas or pics. . . what should i use to make a new xmember.
    sm465/np241
  2. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    If your problem is the cv hitting the cross member, I have that too. I am going to clearance the member and weld in a plate under where I cut.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    do the cut and plate thing
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Can you post some pics of your problem? I'm surprised you have that kind of interference, it’s generally not an issue with stock trans/case setups.
    That said, how you approach the problem will probably depend on how much interference you have. If it's not much, it would probably be fine to notch the lip and plate it, maybe tie into a skid plate at the same time. On the other hand, if you've somehow gotten yourself into a place where you have significant problems, a custom cross member is the only option that will provide a long term fix...
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    He has 10" springs, thus the interference issues.
    I had to clearance grind mine, but not much, but I've only got 6" of lift.
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Ahhh, I figured it must be extreme lift. Don’t have any experience with those I’m afraid. But my comment still stands, the answer depends on how much interference, how much travel is expected, etc…
  7. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I have a 4" lift and had to clearance it. /forums/images/graemlins/dunno.gif
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hmmm, must be the case/adapter combos causing trouble. 241/208 have the front reduction planetary housing so that would put the front output further back. Most everything I've ever fooled with in a GM has run a 205, other than a no lift 76 Scottsdale with a 203.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Both me and Bryan both have 205s.
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Ok, I give, I'm beat. /forums/images/graemlins/rotfl.gif I have no idea what the problem would be, apparently I've been "lucky"? Nah, can't be... must be something else... /forums/images/graemlins/histerical.gif
