crossmember fabbing Q (dual t-cases)
Discussion in 'The Garage' started by BranndonC, May 23, 2005.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    so i'm fabbin my dual transfercase crossmember this week probably or next week. anyway just wondering if i need some sort of poly bushing there or if i should just bolt the cases straight to a crossmember, and if i need bushings, what should i get, something generic? I figure thinner is better, more ground clearance. just trying to get some ideas before i start. does anyone have any insight that might help me along the way?
  2. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Jeep body bushings work good for me I also added a fender washer to each one.
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    u deffenently need bushings, unless u are runnig solid motor mounts. use the same type bushing on the t-casses as u have on the eng mounts. poly on both or rubber on both. i would mix allows different rates of movement & can cause tranny cases to crack. i used 4 factory style poly bushings for mine. i modified 2 factory crossmembers for my doubler.
  4. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks, i have a 203 cross member now, i'll mess with that and see about making one for the 205, i'll see what works and get some poly mounts for it. thanks guys
