Crossmember hitting oilpan......
Discussion in 'The Garage' started by camok10, Nov 19, 2004.
  1. camok10
    camok10 1/2 ton status
    May 1, 2004
    288
    Tucson, AZ.
    Pictured below is the oil pan on my truck and the crossmember that ties into the frame and motor mounts. the crossmember was rubbing on the pan before, just enough to scratch the paint off, but now that i have installed a one piece gasket thats about an 1/8in thicker, the crossmember wont easily go back under the pan. I cannot remove the crossmember, so if i have to modify it, it would have cramped in the truck. Either that, or i have to get taller motor mounts, or dent the pan for clearance. What do you guys think? I could just pound the bitch in there and hope for the best, which is what I almost did just now, but i figured i'd ask for opinions first. its a 73 K10.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    sure your motor mounts aren't shot? Seems like the motore is moving around and contacting it. Can't think of it being so close that 1/8th of an inch would make it rub but I've never done it so /forums/images/graemlins/dunno.gif
  3. camok10
    May 1, 2004
    288
    Tucson, AZ.
    truthfully i think its the wrong crossmember or something stupid like that, because the pan is correct and ive never seen one hitting before. The mounts may very well be shot as well. it rubbed before, and now its a little too tight for me to not worry about it getting through the pan eventually.
  4. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    The steel plates that bolt to the block are different height on passenger cars VS trucks--the 4wd trucks use the ones that have the thru bolt hole 1 inch lower to raise the motor up higher--some 2wd use the car style ones that have the hole closer to the block to make it sit lower.You might have the "short" pads on your motor if its been swapped in,thats about all I can think of.You might be able to "shim" the motor mounts where they bolt to the crossmember to gain some height--I found a shim on the 86 305 van motor I put in my truck,but there was only one on the drivers side.Some 4x4' used plates under the steel pads that bolt to the block for the tranny/transfer case support rods--if yours had them and were removed,it would lower the engine the thickness of that plate-about 3/16-1/4 inch... /forums/images/graemlins/thinking.gif
  5. blaznjon
    blaznjon 1/2 ton status
    Mar 6, 2004
    153
    Seaside CA.
    Looks like the brackets that bolt on the block are small block motor mount brackets on a big block. JB
  6. dyeager535
    26,982
    191
    Check that the crossmember isn't cracked where it is bolted to the motor mount "towers".
    My dads '74 had the balancer rubbing on the x-member from cracked x-member, and my '81 frame was also cracked in the same area, but not so bad that the balancer or pain hit the x-member.
    Later on (mid 80's I guess) the x-member was redesigned to strengthen it overall, and is what I used to solve my problem.
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    motor mounts are toasted or incorrect
  8. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    I vote for the motor mounts being bad or incorrect.
