crossmember interchangability
Discussion in 'The Garage' started by beater_k20, May 22, 2005.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    a member of another board is looking for a trans/case crossmember. he has a 350/203, and i have a 465/205 crossmember. will these crossmembers interchange?
  2. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    i believe the 350/203 uses the flat style cross member and the 465/205 uses the W shaped. they will require differant adapter foot height. but correct me if i am wrong...
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    every thing 84 and older used a flat crossmember, everything 85 and up used a W or S crossmember.
    i think the 203 crossmember is shorter than the others, so it would push the tcase up more if used on something else. the 205 has a bigger cut out for the CV (or is it the 208)
    i know there is some differences that you wouldn't notice unless you had all side by side.
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Between my two '73s, one a 350-sm465-205, and the other (parts junker) was a 350-350-203, the members were the same height (and flat), but the automatic one was mounted a little further back on the frame (not too much problem there), but the bigger problem was the giant oval mouting holes in the middle of it were shifted right-left, compared to my sm465 one. Go figure....
