crossmember: one piece vs. two piece
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Feb 15, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    can anyone recall if the crossmember at under rear cab wall differs from one piece to two piece rear driveshaft ?
    IE: could i put in a two piece shaft in place of a one piecer if i have the mounting bracket for the carrier bearing ?
    thanks for anything
  2. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    You talking about that little x-member that bolts across under the back of the cab..
    It is not a frame support..it is a hangar for mufflers and cats...
    Take it out if it interferes with the 2 piece drive shaft x=member
    You will need a x=member for a 2wd/2piece drive shaft..you will need to drill and bolt it..stock its rivited, so if you get one at pick n'pull, you will need a battery powered grinder or drill
    Trickey, because it rivits/bolts to the top of the frame rail, and the bed is in the way, so you have to get it at an angle between the frame rails..
    /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
    I looked and measured my frame for the same reason... /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
