crossmember question
Discussion in 'The Garage' started by sandawgk5, Jun 7, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    My crossmember met a rock and it tweaked it to the rear and also jacked the frame flange where it bolts up. My question is will any 208 crossmember work or do I have to get the same type that is in there? The kind I have is the one with the hump on the passenger side only. Also I tried to straighten the frame flange out but was not that succesful can I just use some 1/4 or 3/8 plate on either side of the flange to spread the load out on more of the frame? Any suggestions or opinions are welcome.
    Ira
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Any 1985 on up short adapter x-member should work.
    Tom
