crossmember right behind rear cab mount crossmember
Discussion in 'The Garage' started by R72K5, Jan 13, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    on 82 pickup,
    the crossmember right after the rear cab mounts crossmembr on the 82 k10 is rusted through all the way on driver side end of it next to frame rail, it is riveted in place with alot of rivets,
    its the crossmember that the second set of bed mounting bolts pass down through and round tube bolt spacer sits inside ends of this member,
    we have an 86 shortbed 2wd out back with a cleaner chassis than this, a frame rail is cracked all the way through in the front so its an unusable chassis, should we grind off rivets and take the crossmember from the 86 chassis, or grind and cut and weld repair the rusted 82 one ? we are restoring this 82 with all new body, so.,.
    thanks
  2. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    use the newer unrusted one... air chisel works great for rivet removal... uses 7/16 bolt IIRC for the reinstall...
    that crossmember is the same for the 2x and 4 by
    this is done all the time when i modify frames
    cam
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    cool thanks :D
    anymore tips or info woul dbe great, if theres anymore to learn, on this subject
    i thought the holes were 3/8" diameter for these chassis rivets ?
    humm
    thanks
  4. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    Im doing one right now in the shop... Ill look at the diameter... I said it without checking...Ill let you know tonight
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok thanks :D
