crossmember strength question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by morphed86k10, Dec 5, 2002.
  1. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    Found out one of the mounting bolts that holds my transfer case to the crossmember is stripped. It was a 3/8" bolt, if I tap it out to 1/2 is that enough thread contact area (1/16 on the thread), or should I try for something like 9/16"?
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I thought that all of them had the big 1/2 or 9/16" bolts anyway. You are talking about the bolt that goes through the rubber mount into the bottom of the adapter aren't you? /forums/images/graemlins/confused.gif
  3. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    drill it out to 1/2" and then tap it to 5/8". The rule of thumb is to tap it 2 sizes bigger than its drilled out to be.
  4. morphed86k10
    Jun 25, 2001
    463
    Reno Nevada
    yeah, thats the one.
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    My x-member bolts that hold the adapter to the x-member are 1/2" bolts...I think they are like 3 or 3-1/2" long...I would go at least to a 1/2" or even a 9/16"...
