crossmember
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Jul 23, 2001.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I have a problem with the front driveshaft hitting the crossmember. Its an 84k5 with a 4" lift, 700r4 and 208. The crossmember has already been lowered. I have the crossmember with the two humps, and I'm wondering if theres another style that would have more clearance. If not what could I do about this problem. Thanks.
    Brian
    <a target="_blank" href=http://84k5.coloradok5.com>84k5.coloradok5.com</a>
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    When I put new 6" springs on mine my cv rubbed the crossmember .I removed the crossmember ,took my grinder and ground down where it was rubbing.That fixed mine.
    "I AM THE HILIFT KING"<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  3. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    When I swapped in a th400 in place of the 700r4 I had to cut a section out of my crossmember and weld in another piece dropped down a little.
