crossover 71
Discussion in 'The Garage' started by rancid, Oct 7, 2006.
  1. rancid
    rancid 1/2 ton status
    Apr 24, 2005
    105
    utah
    im doing a crossover steer on my 71 3/4 ton crewcab, it has a 44 front and i got a steering box from79 2wd truck. i will have about 10 inches of lift and will need a dropped pitman arm. and just wondering what dropped pitman arm everyone is used.
  2. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    I'm headed to the wrecking yard in about 1/2 hour to get one myself. I found a steering box in a 2wd 74 suburban that im gonna grab. I bought the sky drag link with the big bend in it so i can prolly get away without much drop. I'm only running 8" of suspension lift with 3" of body.
    I looked a couple of days ago and for me, i need a ford pitman arm cause all the chevy ones have the ball joint built into the pitman arm and as you can see i have the ball joint on my draglink.
  3. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Superlift Part Number 1104
    Application is 78-79 F-150 for a 4" lift... - AND I had to re-taper mine for a Chevy Tie Rod End
