crossover and high steer with rear springs up front
Discussion in 'The Garage' started by MudFlap, Sep 17, 2004.
  1. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    I already have crossover and high steer (in front of the axle) and the axle is moved about 1.5" forward with about 8.5" of suspenion lift. I read that you cannot do the rears up front with crossover and high steer because it moves the axle forward and the draglink hits the tie rod, right?
    But where does it hit at, because if it hits near the pitman arm I figure that since I am running more lift than just with stock rears up front I might be alright. Because right now everything clears for me and I don't see another half inch changing that much.
    I was planning on running either BDS or tuff Country rear lift springs up front, probably 6" springs and removing a leaf or two to make the eye to eye length longer to give a better shackle angle. Right now I have problems with my draglink hitting my passenger spring, due to the zero rates, so if I put rears up front I could take out my zero rate and keep my axle moved forward and help my spring to draglink clearance.
    Does anybody see any problems with my plan, especially the draglink and high steer clearance issue?
    Trey
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Most people who swap 52" springs up front have to convert there high steer back to low steer or convert to behind the axle highsteer setups.
    Harley
  3. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Yeah, but I am trying to figure out why they have to do it. I think that I might be because their dragink on the pitman arm side hits the high steer rod. And since I will be going with about 4" more lift I will have about 4" clearance than most people, so I am thinking that I might not hit.
    Trey
  4. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    i can't say for certain because even though i already run 52''s up front with x-over/histeer the tierod is rear mounted. but... i'm pretty sure that the reasoning is just like you said, when the axle is moved forward it puts the tierod directly under the pitman arm so if your setup will compress far enough (which it probably still will) the pitman arm will get squashed against the tierod binding up your steering.
  5. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    Im pretty sure you have to run x-over steering because it moves the axle forward 2", and the stock steering setup can't work right. I dont know if you will run into trouble with histeer tho, someone else can tell you that.
    Later
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    You have to run crossover with the 52's up front. And you CAN run histeer if you use arms that locate the tie rod behind the king pins. Clicky...
  7. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Thanks fellas
    Trey
