Crossover...Bent ot straight draglink
Discussion in 'The Garage' started by readymix, Jan 16, 2005.
  1. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    What are the benifits of running a straight draglink. I understand that the bent one is too clear the engine crossmember, but i could just build a new one if the straight draglink is better.
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Straight drag link is just cheaper, the bent one not only clears the crossmember but it also runs the TRE's at better angles to the mating parts making them last a lot longer.
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Some belive the bent drag links can ontinue to bend if enough force is placed on them. I built my own bent drag link (and another for a buddy) and have yet to have any problems with either of them.
  4. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    what they said. I have a bent one from rockstomper, zero problems.
    j
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have the other one built by az-k5 and it works great. It barely touches the engine crossmember and the TRE angles are better then if you run a straight draglink. Our draglinks are made from 1.5" .250 wall DOM.
    Harley
  6. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I would say the angles play a huge role in weather it is straight or bent. Mine I would say is the max static angle you would want without a bend in it.
  7. readymix
    May 30, 2004
    6,706
    26
    Why would the angle matter? Other than the effeciency of the steering system.
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The steeper the angle, the faster the TRE's will wear out
  9. readymix
    May 30, 2004
    6,706
    26
    Of course.....not sure why i even asked that question.
  10. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Mines bent from Sky, but it was because I have a big lift!
  11. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    I'm running some "high angle" joints from ORD but if your not careful with the angle not only will wear be an issue but you can limit the axle/steering when articulated.
  12. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Bends turn the draglink into a spring. The larger the bends, the more it will spring under load. At slow speed you may not even notice this, or care if you did notice. At hwy speeds this could be a problem.
    It is easier to cause a bend failure in an already bent link. You best friend there is OD, not so much wall thickness.
    The better, and much more difficult, solution is to lower the steering box (drop pitman's wear out the box) and raise the steering arm on the knuckle. Didn't say this was the practical solution, just the better solution. :)
  13. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    That is a horrible solution. Your u-bolt plate would go right for the pitman arm and the raising of the arm on the knuckle cause extra leverage on an already stressed and questionable stud design. I have to limit my up travel just to keep that from happening as it sits right now (4" springs) and have seen 4 different arms shear off on 4 different vehicles.
    There is a lot, (and I do mean a lot) of hearsay crap on x-over. The spring in the bent link is less than negligible (but does exist) when you take into account bushing/leaf spring give (don't forget tire squirm). I also strongly believe that I would rather have my link bend heavily than have a straight link shear a TRE. It takes nearly the same force to do either.
    There is not any difference in an ORD sold TRE than the ones you get at the local parts store. If there was a company making some "special end" than it would be all over the net, or so costly to make that it would not be marketable.
    Bottom line, a bent link allow a better angle on the TRE's and clears the factory x-member usually without further modification. Those are the two main reasons to run one. If you are going to go hydro assist as well than there should be no worry about bending an already bent piece. You will shear the ends on the tie-rod or break a knuckle first.
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I run a Sky bent link, and a hydro ram.
    May go full hydro but other than that no complaints at all about my $320 crossover and $100 hydro.
  15. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I prefer the bent style due to reduced operating angles. Mine came from ORD several years ago. I've had no problems with it, but I did twist off a few sector shafts before going to hydro assist.
  16. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Note that I didn't say it was the practical solution, just a better one. I'll take a straight draglink over a bent one any time it's reasonable to do it.
    I'd like to see that data.
  17. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    Mine is straight with 8" lift
    here's a pic
  18. readymix
    May 30, 2004
    6,706
    26
    Who made that mount for the axle side of your Hyd ram??
  19. jstevenj
    Aug 28, 2002
    94
    north Miss.
    I made it
    I made it as well as all the mod's.
    crosover steering arm
    clocked pitman arm on stock 4x4 steering box
    draglink
    rear disc brakes
    twin stick for 205
    http://jkwoffroad.com
    Thanks, Steven
  20. nvrenuf
    Jan 7, 2002
    13,075
    245
    Mobile, Al.
    Do you still make the crossover arm for the 4wd box? If so, how much is it?
