Crossover Draglink. 1,25 OD .120 Dom or .250 Dom?
Discussion in 'The Garage' started by JpEater, Oct 3, 2006.
  1. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    I have a friend that is doing crossover on a K5 with a Dana 60 and he wants to use 1.25 OD Dom with .120 wall. I don't think that it is strong enough cause it is too thin. All I have ever seen for sale is .250 wall. I want you to help settle the debate so what do you think should be used. Oh yeah It is a 1 ton K5 on 40's. Thanks
    Trey
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    .250 Dom
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    X2
    .120" wall is for rollcage bracing, grab handles etc etc.
    rene
  4. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    0.120 would probably work... especially if the guy doesn't have hydro assist (or full hydro!)... but 0.250 would be the smart choice.
    j
  5. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    Thanks for the thread trey...nice way to word it too. Like ive said, itll work for what i need for a few months...esp since the truck WILL NOT see dirt till prob after the new year and WILL be on 36x12.50s for a while. No, its not ideal, but it oughta work just fine for the time being. Its not like it can't be sleeved later on...
  6. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    yeah, no offroad, no hydro, should be np. I have a stock D60 tie rod laying around here somewhere... it ain't no where near as strong as 1.25 x 0.120 tube...
    j
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    It also depends on if it is bent or not. Bent ones take a shear load along with a compressive force.
  8. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Yea I dont see a problem with it as long as its a straight draglink, hydro assist or not.
  9. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    As with anything with our rigs, if you have a change to go beef-ier, then do it!.
  10. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    umm... hydro would put LESS force on the draglink, no? In most peoples cases the run their rames to the tie rod so this would remove alot of stress from the draglink...
  11. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    good point, I was thinking about tie rods for some reason. That said, if they are both attached to the steering arm (by way of knuckle or not) if a ram is pushing it one way or the other, the force should still put pressure on the drag link... right?
    j
  12. 79k20350
    Nov 22, 2004
    7,757
    Ct
    The only way i can think it would put more pressure on the draglink if the drag link was trying to move in the opposite direction (which cant happen in this situation) because both are moving in the same direction at the same time it should relieve pressure from the draglink. this is why hyrdo assist makes it easier to turn, if it pur more pressure on the draglink, then it would still be hard to turn because the box would have to overcome that force.
  13. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Go with the .25 wall. There are reasons why you mainly see 0.25 and 0.50 wall tube used. .120 is too weak. Period.
