Crossover for 10b??
Discussion in 'The Garage' started by 85mudblazin, Oct 1, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    All that I need are the flat top knuckels off the old dana 44 right?? What other stuff has to be done before I can buy the parts from ORD?? any machining??
    -Chris
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    the knuckle needs machined for the 3 studs. also need a 2wd steering box or selector(sp) shaft out of one. and a ford or jeep arm.
  3. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    836
    Pinckney, MI
    Let me know how this works, im thinking about doing this to my 10blt instead of hunting for a D60 damn those things are expensive!
  4. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
  5. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    I did this for my /forums/images/graemlins/burb.gif until I could come up with the funds for a darn D60. I installed d44 knuckles that were machined and tapped onto my 10 bolt. I used a 2wd sector shaft and put it into my existiing steering gear box and a drop pitman arm for a furd. I used a PartsMike steering arm for the right side knuckle and Sky bent drag link and tie rod (still has to be put on). It works 10 times better then stock and I could not even imagine how it steered before this.
    If you look in my webshots, there should be some pics of the front end when I did this.
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Any idea on how much it cost you in the end??
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I'm going to do this, D44 knuckles (traded parts), drilled tapped knuckle, arm, draglink with TRE's, pitman arm (traded for other parts). Traded speakers for a NEW remanf 2wd box which I'll drill myself and add hydro assist. Total cost for me... about $140 in parts I had. When and if I find a D60 to put in I'll toss the stuff in my DD if it works out well and limits bumpsteer.
  8. funkycold
    Apr 22, 2002
    435
    Orange County, CA
    D44 steering knuckles, drilled and tapped, $150
    Steering arm, studs, nuts, washers, $150
    New upper and lower ball joints, $75
    dropped steering arm (ford), $150
    Sky Mfg - bent drag link & tie rod with ends, $300
    2wd sector shaft, $50
    Total + any misc items -------- $875
    I think that is most of it for the steering anyway. I also got all the 8 lug stuff, hubs, back plates for $200 and then added new rotors and used my old calipers.
    I know I probably could have gotten a D60 for a little bit more, but I had to go with the cross over steering and it was easier to do this first and then wait for the D60.
