crossover-high steer pros and cons?
Discussion in 'The Garage' started by madmike, Apr 15, 2004.
  1. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    Thanks for all the great replies concerning my crossover steering question previous post. Since I'm definitely going with crossover steering, I'm also thinking about going with high-steer arms as well.
    Are there other advantages to having high-steer, other than moving the tie rod above the leaf springs?
    What disadvantages are there?
    I'd appreciate responses from people who have this set-up on their rigs, and that actually use them for four wheeling. Thanks!
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The biggest draw back to histeer is the heavy load it puts on the king pin. Some people fear (my self included) the extra stress will cause the springs to wear out really quickly and can even break a knuckle, especially when using a hydro set up (as the load of turning both tires is placed on one pivot point). It sure does make sense to have the tie rod above the springs though. A lot of guys run it with few problems just be ready to replace the king pin springs often (the upper kit is only $18ea so why not). You could also shim the spring for a little less give.
    just my .02
  3. madmike
    Jan 23, 2002
    496
    ohio
    That's a good point, I hadn't thought of that! /forums/images/graemlins/thinking.gif
