crossover problems :(
Discussion in 'The Garage' started by mudhog, Mar 24, 2006.
  1. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    well i have my crossover in. but im having a strange problem. after a turn when going say 40 or more after the turn when im going straight again it will rock side to side like a boat in the waves:confused: anyone else have this happen? anyone have any ideas on how to fix this?:confused: :confused:
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    could be bad shocks but most likely its cuase you aint got a sway bar:wink1:
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    that could be but why did it only do it AFTER i did the crossover and not before?
  4. 79k20350
    Nov 22, 2004
    7,757
    Ct
    not sure:dunno: but crossover isnt the cause of a sway, or at least i cant see why it would be...:confused:
  5. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I don't think it would be the lack of a sway bar, I have x-over and NO swaybar, mine drives fine. Not to say that your dumb, but did you check the frame for cracks?? All the bolts tight?? TRE?? DLE?? I had a DLE come loose, but that was more like D/W than rocking side to side....
  6. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    The answer
    Check your front ubolts and shackes and make sure it is all tight and then go get a second steerign dampner. the cross over steering is great but the disadvantage is in the geometry. the short stock arm is positioned front to back and will alleviate this effect. When the cross over steering is in place it is side to side and will allow this wobbling action.
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    hold on is it body roll or is itthe truck moving side to side?
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you know how the old hoopty cars come to a stop and the backend keeps bouncing? its like that but side to side:confused:
  9. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Toe in toe in toe in!
    I ended up taking my truck to the alignment shop for the very same thing, as I couldn't get it right with a tape measure.
    I also did 52"s up front when I did crossover, and they are muuuushy in comparison to my old Rancho's... so when I got up to 30, the thing would shake like you'd never believe ... puckered my butt to that seat something fierce.
    -- A
  10. chopped&bobbed77burb
    chopped&bobbed77burb 1/2 ton status
    Oct 5, 2005
    925
    milwaukie,oregon
    I think you have the death wobble . Does it shake the steering wheel back and forth ? . shim the king pin's with a few fender washers (3/16) and toe it in about 1/8 to a 1/4 inch . I at one time had jacked my front end up to check wheel bearing and what not and I stepped on the bottom part of the wheel and the whole wheel / knuckle unit dropped down becuase of the king pin spring :eek1: . I guess they were not ment for 42" swampers . I get a little bit of shimmy around 25 but it goes away when I speed up . I have only one steering dampner and I think if I had 2 it would be better . I damage a steering dampner up at goat Mt and lucky for me I brough a spare as I could only do about 20 mph . any more and it would shake the steering wheel out of my had . all my parts are new up front . I think I also have a out of round 42" tsl :rolleyes: imagine that :haha: . I wonder if the pan hard bar I'm making will help help any . I think having longer than stock front shackles makes it worse as it has more leverage to flex back and forth . good luck .
  11. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    trust me i know what deathwoble is and this is NOTHING like it. this is just like being anchored out in a boat and having another boat go by. not front to back rocking but side to side rocking. I'm thinking that dremu might be on the right track as it NEVER did this before the crossover. and i had wicked deathwoble before the crossover but none since
  12. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I think alignment is causing the problem too. If one tires toe is farther in than the other during a turn, then you will get that front end wash out feeling. In NASCAR they call it "pushing". I am just guessing, but my guess is that with cross-over steering, any miss-alignment is probably more amplified than with the factory "push-pull" type system.
  13. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Mine does the same thing. It is worse with lower tire pressures. I have 2 choices when it starts, nail the brake or nail the gas. I consider it death wobble. I am running 40" tires and highsteer with no stabilizer.
  14. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    this is NOT deathwobble. trust me i know what that is.
