Crossover questing re lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MNorby, Oct 15, 2002.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I got the 60 ready and looking at how to do cross over. I currently have 4" lift but am planning on a 6" lift later on. I read that w/ 4" I will have crossember clearance problems so will have to put a diff style crossmemebr on such as MOOs or use a kinked draglink. Now my question is if I design it for 4" lift now what would happen when I put 6" lift on it. Also can you put a dropped pitman arm of sorts to clear the crossmember? Or would I be best off to wait till I put 6" lift in to design the crossover steering?
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Im running a 4" lift and am about to install my crossover. Im gonna be running a 4" dropped draglink and a 4" dropped pitman arm. This is the same setup Mudzer is running with 6" lift and he said he had no problems with the stock crossmember.
  3. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    If you encounter crossover interference, consider just trimming your stock x-member...I have a 6" lift and had to just barely trim the edge off the x-member (I am using a straight drag link, not a bent one)...this was the cheapest way to make it work. You can save a lot of money and work by just trimming the edge off...
  4. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    My drag link hit my crossmember pretty good. I am running a straight drag link with 6inches of lift. I ordered a new crossmember from M.O.O.. I havent got it yet but it's a sure fix to the problem.
  5. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    I'm assuming that you have a 4" drop pitman for the straight draglik right....Do you thinkI will be able to do the same with a 4inch lift. I am going to be running a highsteer over the springs and am wondering about clearance.
    is a bent draglinkthe way to go?
  6. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    who makes bent draglinks? Is there anything wrong with using the bent draglink vs a straight one?
