Crossover question ORD Kit
Discussion in 'The Garage' started by MTBLAZER89, Jan 6, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    From the ORD website
    Our draglink is bent to help clear the factory crossmember. We cannot guarantee that you will not have some contact with the crossmember, it may require some trimming to work under all suspension conditions
    Does anybody have this problem with x-member contact? If so with what suspension and how did you fix it? Pics would be great /forums/images/graemlins/thumb.gif
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I have 8" of lift with ORD crossover steering and I never rubbed my engine crossmember. I think that statement is for nearly stock folks and those with really, really, really sick travel.
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    So I have 4" and plan on some zero rates. Should I be ok?
  4. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    should be. if not grind an inch off the crossmember or something.
  5. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Go with the Missouri Offroad crossmember. Good quality product.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not all of us want to go through all that work.
  7. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    If you don't mind tightening your bolts everytime you wheel it then go for it.
  8. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    confused? /forums/images/graemlins/confused.gif
  9. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    /forums/images/graemlins/confused.gif Yeah what do you mean?
  10. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    [/ QUOTE ] [ QUOTE ]
    Factory rivets very rarely come loose. Bolt in cross members will.
    I trimmed my cross member w/ a sawsall. About 5 min. I also use a straight Drag Link w/ only about 3" lift.
  11. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    I have sold several of these crossmembers(100+) This is the first I have heard of problems with the bolts coming loose. The only reported problem was a customer trying to use it with less than four inches of lift and the subsequent contact between the differential and the crossmember. If someone has had this problem please contact me for future reference. /forums/images/graemlins/deal.gif
  12. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah I pretty much figured if that was really a serious problem I would have heard about it before now /forums/images/graemlins/thumb.gif
  13. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    LOL...come-on...the install took me 2 hours...
    DO it now...while that axle is out!!! /forums/images/graemlins/thumb.gif
  14. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I also have a MOO crossmember, I installed it when I yanked the SBC and replaced with a BBC. Install went smoothly, and like someone else mentioned, I've had no problems with bolts loosening. An excellent product, Steve!
  15. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Well, in the three Blazers I own, all three have bolts holding the engine crossmember in. I'll assume that all three used to have rivets at some point. But, if the bolt thing were always true, then anything bolted to the frame would potentially have the same problem wouldn't it? With all the stress of twisting and flexing, the ORD shackle reversals, the bolt in tranny crossmember, the side bolt in TC case mount, etc. would all potentially come loose. I would think good bolts and locknuts/washers with an occasional check would work fine.
  16. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    meh, use metal locking nuts + some loc-tite and they wont be coming off. If they still have ya trouble, spot weld em on. /forums/images/graemlins/grin.gif
    j
