Crossover question
Discussion in 'The Garage' started by nvrenuf, Feb 28, 2005.
  1. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    I have a chance to get some used ORD stuff but I'm curious if it will work for me. The parts are coming off a truck with a 4" lift, I wil be using 6" + Zero Rate. Here's my question -
    Will the drag link made for a truck with 4" work for one with 7"? I know the parts will/should bolt up but what about the drag link length and bend? ORD told me there is a 1" difference in length but is this a real issue or can it be adjusted out? Will the bend be enough?
  2. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    You should be able to adjust it, depending on how much adjustment can already be done and what length the TRE's are. If you need another drag link I have let me know I have a hook up. With 7" you can move to a straight bar and not have any clearance issues.
  3. sweetk30
    Nov 1, 2004
    25,550
    543
    horseheads , ny 14845
    the drag link bar is 4-6 and then 7-up for length i was told when i orderd my stuff. the bend in the link is for tire rod angles to help long life. and the arms will bolt up to axle but the zero rate will interfeer if using crossover histeer setup andmight cause issues with arm on just crossover only. i have heard you need to use a block with arm to clear arm if using zero rates in frt.
  4. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
  5. AkMudr
    Dec 30, 2004
    917
    Alaska
    I know alot of people have adressed the issue of having bent link with 6+" of lift versus a straight one and that a bent link has a tendency to keep bending, so to speak. Personally I would get a straight drag link. If ORD says theres only 1" difference theres probly enough thread left to adjust it. If you already have the lift on I'd bolt up the drag link just to be sure, if not get a new one cut for 65$. You could probly turn around and sell the bent one and save some $$ that way.
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I don't know for sure, but what I can tell you is this. The drag link I got from Steve was for my 6" lift. The length is such that the ends screw in almost completely into the rod (including Jam nuts on either end). Sooo... If the 4" one is actually an inch shorter, it will work. HTH
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ya i second that, mine was to long, my steering wheel is crooked:D
  8. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    Ok, looks like I'm on my way to join the crossover club. :D
    Thanks for all the help and info from everyone. I'm glad to hear the ORD links run a little long too. :woot:
