crossover question?
Discussion in 'OffRoad Design' started by aj_tatted, Jan 30, 2004.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    i installed a crossover system on my 84 jimmy, however the arm doesn't seem to smoothly clear the frame brace.
    do i need to get a new pitman arm, or raise the brace or what?
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Did you swap out the 4wd box for a 2wd model ? or at least the sector shaft ?
    And what pitman do you have on there right now ? Most use a dropped Ford superlift 1104 arm.
    Blake
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We need to know a lot more details:
    What pitman
    what draglink
    what steering arm
    how much lift (probably in your profile but still good to have in the text)
    what "brace" are you referring to? are you talking about the crossmember in the frame?
