Crossover spacer
Discussion in 'The Garage' started by Hossbaby50, Apr 15, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I just read for the first time that I might need a spacer for my D44 steering arm when I convert to crossover.
    I am running 4" lift springs with 1" zero rate. Am I going to need a spacer and new studs for my knuckle? I am going to be using a bent draglink if that matters any.
    If so how exactly do I get the old studs out of the knuckle? Thanks
    Harley
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm running the exact same setup as you and am going to have to do the same thing. If you want to save your existing studs, use a jam nut to remove the studs....or get a stud remover or you can do what I did and tack welded a nut to the stud and took them out /forums/images/graemlins/thumb.gif
  3. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    anyone else have knowledge on this? Thanks
    Harley
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I called Sky yesterday and he said I prolly will need a spacer too with the 0-rate spacer is only $15.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    You need new longer steering studs though don't you? Do you need the 1/2" or the 1" spacer to clear?
    Harley
  7. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i had to run the spacer.....i got mine from poison spyder....i used 5/8 studs instead of the 9/16 ones cause i broke the 9/16 off the knuckle wheelin /forums/images/graemlins/eek.gif.....also i keyed the spacer and arm together so they cant move....
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    poison spyder
    got a link?
  9. leadfoot067
    May 14, 2001
    1,563
    web page
    then go to crawler parts,then,hysteer arms and youll find the block and the 5/8 stud kit
