Crossover Steering - 2wd gear box?
Discussion in 'The Garage' started by hero, May 4, 2006.
  1. hero
    hero Registered Member
    Oct 21, 2002
    65
    Omaha, NE
    I'm a little confused. I already have hydro assist on my rig, and now I want to convert to crossover steering. I have the arms installed, but I'm confused about the steering box. I was thinking that I just needed to swap to a 2wd steering box and change out the pitman arm. I do have a 2wd steering box that I got off a donor truck that I was going to drill and tap for my hydro fittings, but the more looking around that I've done it sounds like I can just swap the sector shaft from the 2wd box into my 4wd box that is already drilled and tapped.
    What do you have to do swap out the sector shaft, is it really just a matter of removing the pitman arm, unbolting the 4 bolts on the top cover and pulling the shaft out? If so I would rather do this than mess around with setting up the 2wd box for my hydro fittings.
  2. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Yes, almost.
    You'll also need to adjust the shaft once it's installed; there's a good write-up here ...
    http://coloradok5.com/forums/showthread.php?t=147102&highlight=sector+shaft+swap
    I even bookmarked it so I don't have to search =))
    -- A
  3. hero
    Oct 21, 2002
    65
    Omaha, NE
    :bow::bow::bow::bow::bow:
    Thank you ! That was extreamly helpful. Thanks a million.
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    i didnt adjust my shaft....
    I just swapped them both out... and was done with it..... worked great.. couldnt get my lines off so I swapped just the shaft.... :wink1:
