Crossover steering arm design??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kickinasphalt383, Feb 12, 2003.
  1. kickinasphalt383
    kickinasphalt383 1/2 ton status
    Dec 6, 2001
    224
    Michigan
    I plan on making my own crossover steering arm for my 60 and I don't know how far to drill the TRE hole away from the knuckle.
    Once I get all the pieces together on my truck (2wd box/pitman arm) I will be able to calculate where I need to drill the hole... so my question is from people that have made their own arms or have opinions on them, how far out is the most ideal position? I know the farther out I make it the more leverage I will have but with less turning radius. So what is everyone's opinion on a good length?
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think most just drill it equal to the pitman length.
    if you find this to be incorrect please post your findings.
    also try a search as I recall a similar thead
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I am doing the same thing and I am going to experiment a little, I want to have full steering capability without my tires rubbing on the springs.
    I think I might end up doing it a little shorter than the pitman arm to get more travel.
