Crossover steering arms
Discussion in 'The Garage' started by 87GMC, Jan 8, 2003.
  1. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    Those of you with crossover, whose arms are you using. Any problems? Thanks /forums/images/graemlins/truck.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I ordered this one and it should be here tomorrow. It has the 10 degree angle, setup of 7/8 TRE, and comes with studs.
    The only downside that I can see is that it does not have a cap welded on, like the ORS one does, so you have to reuse your stock cover. I don't think it's a big deal.
    -- Mike
  3. DaveCowley
    DaveCowley 1/2 ton status
    Feb 18, 2002
    196
    Provo, UT, USA
    How much did you pay for that one? Where to go to get it?
    Dave Cowley
  4. 87GMC
    Nov 5, 2001
    653
    Olathe, KS 66061
    ttt
  5. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I got that same arm. One problem. I told him to tap it for GM TRE, he tapped it for DRE which have a bigger taper than the TRE. So it didn't work completely right.
  6. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I used the Tri-County crossover arm on my D44.....no complaints.
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I ran into that same problem. I used a few washers to put it in and seat it. Seems to be working but I'm not sold yet.
  8. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    So it is sitting deeper in the taper than it would had it been the correct taper? That may run into binding problems when you flex that thing out.
    I ran into the same issue when I started putting parts together for my Xover and how I fixed it was I just put 1 Ton ends on the draglink.
    You technically should be putting the correct size end into the taper it was designed for. Any other and you could run into breakage problems down the road. Just a word from someone who's been there. /forums/images/graemlins/smile.gif
    It's not hard to install the correct end and possibly rebuild a draglink so that it's put together correctly.
    Hope this helps....
