Crossover Steering conversion...
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Greg72, Mar 5, 2001.
  1. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Anyone done a crossover steering conversion? I found out that all my front-end components (ball joints, tie rod ends, etc) are wasted. That's why it steers so BAD. I figured that if I have to pull the front end apart, I might be better off doing the crossover steering conversion at the same time.
    I hear that the steering box needs to be swapped out for a 2WD version (turns the OTHER way) and it looks like there are lots of adapters, etc.
    What should this realistically cost and is it worth it (for those of you who have done it)????
    Thanks,
    -Greg
    '72 K5 w/427
    Thumpeta-thumpeta-thumpeta..... ;^)
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Duno the cost involved but a few have done this in the 73 and up forum! One mod that you may have to do is a custome crossmember were the motor mounts too. Not sure about our rigs but I know that some other yrs had to replace the stock crossmember!!??
    GoodLuck
    Oh ya you ready to whell that thing yet???
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    You can check out what Rockstomper made for Shawn at http://www.off-road.com/chevy/tech/d60crossover/
    And here is where Glen did it on a Dana 44 (Glen is our Modulator, or something like that.) Anyhow, he even gives part #'s <A target="_blank" HREF=http://www.off-road.com/chevy/crossover/>http://www.off-road.com/chevy/crossover/</A>
    Hope I was some help.
    See Ya,
    Keith
    [​IMG] Born to Drive My K5 [​IMG]
  4. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Burt4x4,
    If I don't get this steering fixed....I WILL be offroad!!! Maybe some morning off the side of Hwy 237....
    I would definitely be a 'liability' to an offroad group right now. And I'd hate to be 'that guy who keeps breaking down on the trail'.
    My time will come, and I will take you up on that. Have you contacted Steve Chin about joining us here?
    -GregB
  5. Burt4x4
    6,854
    hahaha LOL I hear ya Bro!!
    Better to fix it now and then when you finnaly get ready for that virgin run make sure you let me know and I'll go with ya!!
    ARQ and I are gonna try to plan something for the late summer FirstGenK5 run #2 so try to have it ready so you can join us!
    Yes I sent StevO an email but have not heard back from him yet.
  6. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Thanks Keith!
    I had found a few of those articles, but didn't fully understand that one was for 44 and one was for Dana60.
    I like the look of those beefier Dodge rod ends...one less thing to worry about!
    -GregB
  7. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    A friend of mine has a '71 with cross over and an 8" lift, no cross member mods neccesary to run a straight tie rod. The first gen cross members don't hang down like the '73+, I suspect you wouldn't have any problems with a smaller lift.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  8. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    The only down-side is that you can't run a front anti-sway bar under the frame because there'd be a linkage conflict. I suppose you could mount an anti-sway bar above the frame (above the radiator?) and run some long end links to the spring plates. We've had to do similar stuff to race cars for one reason or another...
    Anyhow, if you're considering an anti-sway bar, this is food for thought.
  9. californiak5
    Oct 25, 2000
    820
    Do some first gen's have stock sway bars? My 70 does not have one or a place for one.
    See Ya,
    Keith
  10. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    First gen blazers Didn't have way bars. Most that do now have been modified 73- up bars, made to fit our trucks. And glad to see some of you guys from Blazer.net on this board!
    [image]http://albums.photopoint.com/j/View?u=1328774&a=9975627&p=33244094[/image]
  11. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    How do you modify the '73- sway bar to fit a 1st Gen? I would like a little less body roll on the street.
    '71 Blazer CST with alot of rust
  12. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    That's good info that I hadn't considered....
    BTW -&gt; I have decided to get 'down and dirty' on this front end repair and do it myself. I didn't own any SAE tools, so I went to Harbor Freight and ordered a set of impact sockets, a pickle fork, etc. Never ordered from them before, so I don't know what the quality will be like....but the prices are VERY reasonable so it was worth the risk! Any specific tools that you would recommend that would make this easier? I don't own a ball-joint press, so I will have to beg to use my neighbors.
    -GregB
  13. Burt4x4
    6,854
    hmm, well Wheelbearing nut socket, torque wrench, c-clip spreader(i forget the name, for removing the hub assy.),dead blow hammer,special socket for removing the threaded sleave were the ball joint goes on the knuckel(forgot that name too). That is all I can think of right now, i'm sure I forgot something..........
  14. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think the words you are looking for are snap-ring pliers and spanner wrench?? Also while you are at it get a 15/16 deep socket for the spring u-bolts. I had to run out to Sears and get one in the middle of swaping the front axle (still ain't back on wheels yet).
  15. Burt4x4
    6,854
    Ya Ya what he said [​IMG]........
