Crossover steering crossmember
Discussion in 'OffRoad Design' started by Rockjunkies, Mar 18, 2002.
  1. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    Stephen, I will be installing your crossover steering kit for a dana 60 and was wondering how much the crossmember will have to be trimmed back. I have already built a crossmember out of 2x2x1/4" square tubing and mounted it to the front side of the motor mount bracket's. But now I am thinking that I should have built them to go inside of the brackets. Will 2" from the front of the mounts be enough, or do I need to build it again?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You'll just have to get it in there and see. Typically a stock crossmember needs very little trimming, usually on the corners only.
