Crossover steering on a '72?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by dr1553, Oct 27, 2001.
  1. dr1553
    dr1553 Registered Member
    Nov 4, 2000
    90
    Lake Jackson, Texas
    Crossover steering on a \'72?
    Everyone,
    I have a 72K5. The steering box and pump are gone. It has 33's on it now and the stock steering setup looks like junk.
    Should I goto crossover steering? What kind of parts do I need? Can I round up parts in a junkyard or do I have to buy a kit? Who makes a kit?
    I have the D44 up front but I someday want to goto a D60. Will I be able to have a crossover setup that can go from the D44 to the D60 and still work?
    Thanks,
    David R.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Re: Crossover steering on a \'72?
    Call up <a target="_blank" href=http://ww.rockstomper.com>RockStomper</a>. They have COMPLETE kits for D60s, 10Bolts, and anything else you have they can custom for you! Talk to Scott, tell him Dan sent you!
    On the steering box, you would have to get a replacement (obviously). You could use a 4x4 box, and change out the sector shaft from a 2WD box! I bought the sector shaft from a local junkyard, and a rebuilt kit for my 4x4 box from AutoZone all for less than $25!
    Hope this is all good info for you! Good luck!
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
  4. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    as far as i know, the crossover steering kit does not interchange between a d60 and a d44
    live to wheel, wheel to live--1972 gmc jimmy 8 inch lift, 37" ssr's, big n bad
  5. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    You need the 2 Wheel drive box the pitman arm. The stock 72 D44 should have the flat top on the right side, it will have to be sent some place to be milled flat and have the 3 holes drilled and taped. You then need the arm fro the rt side which will only fit the D44. You done nned the drop rod but since you do need the drag link any way why not. And yes I have this on my 72 now.
    72 Blazer CST 400TPI NV4500 NP203/205
    01 Suburban 8100 2500 4X4
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Hey Ken... Do you have a front bar on your Blazer with the crossover steering? I'm not willing to get rid of my front bar in order to go crossover, but if there's a way to get both at the same time, I'm going to want to do it.
  7. clarkekent
    clarkekent Registered Member
    Sep 26, 2000
    69
    NY
    Check out http://www.jeepxtremes.com/
    They make crossover steering systems for Jeep Dana 44s and Dana 30s... I'm sure they can lengthen the steering rods to fit a full size GM
  8. blazer72
    Apr 13, 2000
    939
    KCMO
    I had put a sway bar on it but had to pull it to make the cross over work. Its funny but even though there is more body lean with the sway bar gone, but it not a problem with the cross over steering. The only things that are trick is the arm for the rt side and the drag link.
