crossover steering pitman arm
Discussion in 'The Garage' started by mostwanted, Mar 29, 2007.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    Did I see somewhere that some are useing a ford drop pitman arm for lifted trucks? Would this lower the drag link and minimize potential contact with the engin cross member? Would this eliminate the need for a custom cross member altogether?
  2. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    A stock ford van (1978-1979) pitman arm on a 2WD GM box will work for crossover, but if you want to avoid customizing the engine crossmember, you could use a drop draglink (ORD, or others), or a pitman arm from one of them too..
    I have also heard that depending on the year of the truck, you will or will not have crossmember clearance issues.. I had to clearance mine with a ford pitman arm and a straight draglink. I can throw up pics if you need em.
  3. justiz00
    justiz00 Registered Member
    Dec 11, 2006
    83
    Central Texas
    I would like pics as my crossmember is not stock. Im guessing from the drivers side looking toward the passenger. Looking down the draglink.
  4. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    This is an aftermarket ford drop pitman made by trailmaster for about $65 new.
  5. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    pics would be great. Especially if your rig is 73-87 style. Thanks makovai. Nice clear pics.
  6. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    For the drop one here is the Superlift p/n: 1104.
  7. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    I've also heard of using a Jeep TJ, cherokee or Grand cherokee OE pitman arm, although people are suspicious of their strength. They were made for a much lighter vehicle.
    JFYI,
    Buddy
  8. justiz00
    Dec 11, 2006
    83
    Central Texas
    Thanks for the pictures. So your running 12" of lift, could you have went with a straight draglink?
  9. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    the closer your draglink is to parallel you can get it, the better both your normal steering will be and how much available steering "travel" you will have for droop. Make sense?
  10. 5trucks
    5trucks 1/2 ton status
    Aug 12, 2005
    169
    Yuma Az.
    This is a pic of mine with the tj/yj arm on it. The drag link isn't straight but i have no clearence issues at all.
  11. BUDDY
    Apr 28, 2000
    744
    Midland, TX
  12. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    Nope. Time to re-calibrate. It's only 4". Wait a minute, i mean the lift!
  13. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    So with ~7" of life one needs 1104 pitman arm and a dropped/bent draglink to get the DL & TR parallel? Guess I need more parts (again).
    I'm going to the 4wd shop tomorrow, can someone confirm or deny this, TIA.
  14. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    x2 on that one im in the same boat...
  15. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    gentlemen, we're all in the boat together.haha. that superlift part number says it fits Jeep J10/20 and wagoneers/cherokees. i thought that was a ford number. thanks.
  16. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    I guess it fits 80-ish Broncos & F150s, too. Either way that's what you need and it works fine. I got mine from Jason at CCOR. They have a link in the vendor page on here. The DL is an old Rockstomper.
  17. twoslo4five0
    Oct 5, 2006
    6,614
    71
    i just bought my pittman from skyy so all i know is its a 4inch drop....im also running a 2 inch tall arm....do i need a bent draglink???
  18. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    is the drop ford pitman arm offer more drop than the tj pitman arm?
  19. thatK30guy
    Jan 12, 2001
    32,076
    55
    The Superlift #1104 is specifically for the '76-'79 F150 4x4.
  20. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    The pic I just posted is the 1104 Superlift and Sky arms. So w/o it your DL will be steeper.
