crossover steering Q's?
Discussion in 'The Garage' started by nicotine, Dec 22, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    alright i need to know a few things about crossover steering i know everything i need what i need to know is if i have a 4 inch lift now and i put crossover on now and later i go a couple incges bigger both in lift and tires will i have to change anything steering wise? also what i the average price any of you guys have setup croosover for a dana 44 ?
  2. ugly
    ugly 1/2 ton status
    Aug 8, 2004
    157
    Denver
    good question, anyone with experience?
  3. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    I spent about $575. for mine, with the hydro assist.... adding a few inches lift should be no problem...
    FLAT TOPS 120-
    Steering arm (sky) 75-
    draglink (sky) 65-
    TREs (moog) 70-
    Tie Rod * (ebay) 70-
    1104 pitman arm 65-
    REMER 1.5/ft 30-
    Ram 8" x 1.5" 50-
    hose and fittings 30-
    * I bought a new early style tie rod because the stock one hit the springs with the flat top knuckles, you could use a zero rate to avoid this.
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I don't think change in a couple inches of lift will effect anything. Price varies around what parts you can get used or cheaper. I got a good deal on Knuckles and a 2wd box, but I still spent around $500 with Sky Draglink, HD Tie-Rod, and a Tall Arm.
