Crossover steering question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by not4show, Jul 22, 2001.
  1. not4show
    not4show 1/2 ton status
    Apr 24, 2001
    280
    Alabama
    I know you need a two-wheel drive box to make crossover steering work, but I've also read that just the shaft can be changed and it will work. Is that hard to do or what?
    Never put a stupid move passed a stupid person.
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I dont think it is that hard to do. I think I am going to do the same thing and just swap the shaft. I have a 2wd box that I can take the shaft out of but not sure if it will work going from a 73 to an 89 box.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  3. shaneopie
    shaneopie 1/2 ton status
    Jan 1, 2001
    172
    stokesdale, nc 27406
    Very easy to do and i think it is going to be the fad of the future instead of trying to find this special year 2wd box you can get about any year and swap it into your 4wd box and you wont have any worries.
  4. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    i am embarrassed to ask this but what is crossover steering and how does it help
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  5. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    You basically take a flat top knuckle and tap it for a steering arm. Run a custom tie rod from the arm to a 2wd steering box. Make a custom cross member. And waaaalah you a wonderful cure to bumpsteer on the trail.
    Heres a link to a review on our site: <a target="_blank" href=http://coloradok5.com/crossoversteering.shtml>http://coloradok5.com/crossoversteering.shtml</a>
  6. tmanofcali
    tmanofcali 1/2 ton status
    Mar 20, 2001
    372
    lodi, ca
    wayne.........just something to think about.....check the input shaft on your 73 box first. it problably measures 3/4" the newer ones measure 11/16" i beleive. check it out. i had a hard time finding a box to fit mine. good luck
    <a target="_blank" href=http://community.webshots.com/user/tmanofcali1>http://community.webshots.com/user/tmanofcali1</a>
  7. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    If you get a 2wd steering gear box of the same years as the one on your K5 the fittings will work. I think up to 79 had flare fittings and after that they went to o-rings. I'm not sure about the year.
    CB
    1973 K5, 400TPI,TH350, 203/205, Dana60/Detroit/5.38 front and rear, 4" lift, 38" TSL's on steel wheels
  8. not4show
    Apr 24, 2001
    280
    Alabama
    Hey shaneopie, does the shaft need to be out of the exact year and style box? For instance, my current setup is a 72' truck w/power steering. So, do I just need to find a two-wheel drive shaft for a 72' w/power steering or could the shaft come from a manual box? Thanks
  9. shaneopie
    Jan 1, 2001
    172
    I believe that the year really doesnt matter but i do think it needs to be a power steering box you get the shaft from. But i could be wrong.
  10. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    If you find a donor 2WD box to take the shaft out of, why not just use the box to begin with!! They're easy to find 2WD boxes, any from 1973-1987 will work, and probably a few more years, but I'm sure that '73-87 2WD boxes are a bolt on replacement for 4WD boxes. Just beware of the fitting change around the 1980-81 model year.
    ken
  11. shaneopie
    Jan 1, 2001
    172
    The fitting change would be the only reason that i know of for not using the 2wd box. If your fittings are the same then you are good to go with the 2wd box.
  12. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Also if you put the 2wd shaft into the 4wd box this would be a good time to rebuild the box using an advance auto rebuild kit.It runs about 35 bones!!!!!!Cheap insurance that your new setup will work properly and leak free!!!!!!
  13. shaneopie
    Jan 1, 2001
    172
    Yeah that is a great idea.
