Crossover steering question
Discussion in 'The Garage' started by Tabb, Nov 16, 2006.
  1. Tabb
    Tabb ROLL TIDE! AGAIN! GMOTM Winner
    May 2, 2006
    3,566
    21
    Heart of Dixie
    I've heard that when going with crossover steering your should replace the steering box with the same era 2wd version. Is that really nessesary? whats the advantages or disadvantages?
  2. mrk5
    Apr 20, 2004
    12,335
    1,044
    Northern Colorado
    You have to either replace the entire box or just the sector shaft. No advantage or disadvantage, just the way it has to be done.
  3. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    y?
    -Avery
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Because the pitman arm needs to be indexed differently and the 4WD pitman arm cannot be indexed differently but the 2WD can.
  5. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    You need the same era box due to different style ps hose connections.
  6. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    ok, I've always heard and just accepted this but never knew why...
    Thanks!
    -A
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    If your box is in good condition (little play and no leaks) just change the sector shaft. Easy job.
