crossover steering questions
Discussion in 'The Garage' started by mudhog, Mar 1, 2006.
  1. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i ordered a crossover steering kit (Dana 60) from http://www.sky-manufacturing.com/ i know i need a 2 wheel drive steering box. but is there anything else i need? is this just bolt in and go? is there a min lift for crossover? i only have a 2.5in lift right now. also anything else need to be changed? cross member or anything?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    beacuse the draklink is bent and you only have 2.5 inches of lift, you might experience bind at full flex. Not really sure though. Hopefully someone with more experiene will chime in.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i do plan on installing my 4in lift that i have. just not ready to do it right now:crazy:
  4. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    with 16,359 posts..... tell me you're joking, right?
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    no im not:confused: just because i have a high post count dont mean i know everything:crazy:
  6. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    You better do some checking on the pitman arm. I would bet that the 4" dropped pitman would hit your upper spring plate with only 2.5" of lift.
  7. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    high post count and doesnt know how to use the search, id say bind at full flex, and why only 4 inchs?
  8. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    your going to need at least 4 inches of lift for everything to clear properly. You might even have to notch crossmembers for clearance a little bit. btw, the steering box is a bolt on and go as long as the fittings are the same for your p/s pump hoses. For example, npt fittings w/ no o ring are the 73-79 boxes and the 80-91 boxes are the o-ring style connectors. as long as lines bolt to the box and the existing pump, the box bolts right on to the frame in the same spot.
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    with only 2.5" of lift, you may need to go with a 79 ford van pitman arm instead of the superlift arm that everyone uses.
    the only thing with the ford van arm, you have to ream it out to use chevy TREs or DLEs.
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    why only 4in lift? because thats what i already have and i fit 39.5's with only 2.5in lift so why not keep my center of gravity low?
  11. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    ok can i install the crossover and then put the lift on SOON just no wheeling before the lift is in?
  12. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Some nOObs in this thread need a smackdown.......................
    Sad that a good person who's help built this site like mudhog gets this kind of treatment...................:doah:
  13. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    oh and i did a search just didnt find the info i was looking for:crazy:
  14. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    X2
    Shannon, with my 4" lift, ORD crossover w/ bent drag link things look a bit tight. I have wheeled it and nothing hits anywhere, but I know it's close in places.
    As mentioned just make sure the 2WD box you get is the same as far as fittings go. It's better if your donor box has a pitman still attached to it, mine didn't and consequently I had to try and find a new pitman arm nut. After a lot of frustration I broke down and got it from the stealership...
    You'll love the new turning radius!! :waytogo:
    Rene
  15. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    Not to highjack, but the crossover gives better steering radius too? I need a new steering box anyways, so I'm going there eventually.
  16. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    gotta be careful of the axles snapping max turn when engaged
  17. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    ok so what i need to know is will this fit before i install the lift? or do i have to install the 4in lift BEFORE the crossover?
  18. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    The pitman arm, and the engine crossmember are going to be the two places where you will be close. The pitman arm vs spring plate should only be an issue on compression, but you don't have much with 2.5" I imagine. If you have the draglink you could sort of hold it up there and see what kind of clearance you have. i would guess for just street driving you would be ok till you get the 4" kit on. This is one of those things like driveshafts it's a little bit different on every rig even with the same specs.
  19. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i will be doing the 4in very SOON just dont really want to do it right NOW lol
  20. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    That's what steering stops are for...
    Rene
