Crossover steering w/4" lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wstolar, Oct 13, 2000.
  1. wstolar
    wstolar Registered Member
    Sep 17, 2000
    46
    Crossover steering w/4\" lift?
    I'm thinking of doing a crossover steering conversion on my front Dana 60'd GM. I only have 4" of lift. Would I see a noticeable improvement in steering performance over my Dana 60 steering block? Is there a minimum amount of lift required for the x-over steering to be installed?
    Walter
  2. Re: Crossover steering w/4\" lift?
    From what I have read on the subject of crossover steering they say do not put it on anything with less than 4 inches of lift. I don't know the reasoning behind it. Maybe safety? Not enough angle to get over the springs? I see no need for it with a 4" lift from my experience.
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>IF YOU'RE SCARED, SAY YOU'RE SCARED !!
  3. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    I only have 4" of lift and the crossover is Phenominal. It really depends on what you do with it. If you run on the street and just some mild trails, you will notice that the truck steers tighter and easier, it also turns sharp to both sides, not just to the left. If you wheel the hell out of it you will really notice TONS of difference there.
    There is no minimum lift required, if I had a stock K5, I would do this setup again.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
    http://depdogsk5.coloradok5.com
  4. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    I had to trim off the bottom edge of the frame cross member to clear draglink and I have around 8" lift. You might have to redesign cross member.
  5. wstolar
    Sep 17, 2000
    46
    Thanks to all who replied, another question:
    Depdog,
    Did you have to do major mods to the front crossmember (as mentioned by Titanic?). I saw the article at 'Off-Road.com' on the x-over setup. I am expecting to have to do some work to the x-member, just wondering if there will be more clearancing need because of the mild 4" lift (vs 8").
  6. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    What about a crossover that goes between the springs and connects to the tie rod? I've seen that done on a couple rigs and it looks pretty strong. I really want a crossover system but I don't want to loose my swaybar, I think I'm SOL.
    Joe
    RIT Mini-Baja http://www.rit.edu/~bajawww
    Team Mudnuts http://www.mudnuts.org
  7. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Don't worry about losing your swaybar, they're not that big a deal anyway, and highly overrated. I could probably use one again on my crewcab that is lifted 10" with 42" Swampers and a 3000 pound, 9 1/2' Lance cabover camper!! It gets a bit of lean in the corners, but I just adjust my driving habits!!
    ken
  8. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    I'd suggest the crossover and the D60 is so easy to do. Like Depdog said, you will have to modify or make a new crossmember which is easier than you think. More info on the D60 is on http://www.off-road.com/chevy. Dana 44 (and 10 bolt) crossover info is on this site and off-road.com.
    Shawn
    87 K5
  9. Depdog
    1,657
    Georgia
    Ken hit the nail on the head with this one. Go out and drive around the block, then come back and take off the big bolts that connect the sway bar to the ubolt pads. Zip tie it up out of the way and drive around the block again, bet you dont notice much if any difference.
    Depdog
  10. wstolar
    Sep 17, 2000
    46
    Thanks to everyone who offered info on the cross-over steering. I decided I will do it. It looks like my truck needs new springs, so I'll replacing my 4" springs in the near future also. Not sure if I'll go 4" or 6".
    Anyways, I emailed Parts Mike and the steering arm is $135. I'll probably order it sometime this week.
    Onto my next question post....
    Walter
  11. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I built disconnects and got them in a few weeks ago. I went wheelin with the top off and didn't feel like reconnecting the swaybar afterwards (LOTS of mud under there) and I never even noticed a difference on the 70 mile drive home. I completely forgot about the swaybar after a few days but when I put the top back on I remembered it real quick the first time I turned a corner. I wouldn't think that just the weight of the top would make such a difference but there was some pretty significant body roll. I guess I'll just have to get that soft top built a lot sooner now and move south for the winter. One of my friends just moved to N Carolina, I think I need to pay him a visit. He's only a couple hours from Tellico too.[​IMG]
    Joe
