Crossover steering ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cliffy, May 8, 2001.
  1. Cliffy
    Cliffy Registered Member
    Oct 8, 2000
    99
    South Lakewood, CO....... FINALLY!!!
    For those of you who have done a cross over steering set-up using a YJ pitman arm, what year YJ did the arm come off of. Also if there are any other pitman arms I can use let me know. Thanks for the Info. Also where did you get your pitman arm, non of my parts stores carries them.
    Coil sprung 71 blazer.<P ID="edit"><FONT SIZE=-1>Edited by Cliffy on 05/08/01 08:24 AM (server time).</FONT></P>
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    There's a whole write up on doing a cross over steering set up in the technical section. http://k5chevyblazer.homestead.com/home.html
  3. Cliffy
    Oct 8, 2000
    99
    Yeah and I've read that but nowhere did I read the model year that they got the pitman arm off of.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Here is a link to one that used a pitman arm from a 1978 3/4 Ford van
    <A target="_blank" HREF=http://65.11.18.114/_private/crossover1.htm>http://65.11.18.114/_private/crossover1.htm</A>
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  5. konajoe
    konajoe 1/2 ton status Premium Member
    Nov 15, 2000
    112
    7
    Massachusetts, U.S.A.
    The steering arm is made from 1"x4" flat stock that was flame cut to the desired shape
    Scary, what type of steel is that 1" flat stock?
    KJ
  6. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    1" Flat stock could be almost anything. Cold rolled bar stock, T-1 plate, AR plate...
    These kind of details should be provided for those of us that wish to do the same mods.
    Personally I'd use the T-1 plate.
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  7. konajoe
    Nov 15, 2000
    112
    7
    Yeah, It's only a steering component.
    They are not that important [​IMG]
    KJ
  8. Cliffy
    Oct 8, 2000
    99
    Do any of you know What Other vehicles that pitman arm interchanges with. "Standard" computer interchange systems say it only interchanges with 77-79 vans, but I'm thinking if it's a signaw box, it will interchange with most other signaw box pitman arms......
    Anyone know for sure, or at least for pretty sure????? :D:D
  9. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    The arm you're looking for is from a FS Jeep, i.e. a Wagonner or Cherokee, the old big ones, not the small POSs. The taper is the same as a Chevy. If you use the Jeep YJ, I believe it has the small tie-rod taper like the Jeep CJ uses. The stock FSJ arm is zero drop, but Superlift makes a 4" drop pitman, part #1104, bolts right to a Chevy 2WD steering box. Call Parts Mike for help (530-885-0673), he can set you up on the CHEAP!!!
    ken
  10. Cliffy
    Oct 8, 2000
    99
    Thanks I'm calling him now, sounds like the EASIEST way to go. appreciate everyone's help thanks again.
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Why would you use those light weight Jeep arms when a heavier 3/4 ton Van arm is available? I remember seeing in the write-up that the author had some concern over using the lighter/smaller Jeep arm and I expect that the Van arm is stronger (at least I would hope so).
    Bad Dog
  12. konajoe
    Nov 15, 2000
    112
    7
    Parts Mike sold me a Skyjacker 4" Dropped Pitman Arm # FA300, after returning the first one he sent me which i believe was off a Fullsize Jeep( the castle nut hit the frame when turned to the left)
    I think the new one is from a 70's F250? Skyjacker's site is down so I'm unable to confirm that application. I measured the taper and it is just slightly smaller than my original 4x4 arm.
    KJ
  13. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    i just test fitted a 78-79 f 150 dropped pitman arm on a chev 2wd box today, it fits. dont remember the make of it though. possibly trailmaster. also, i called local les schwab tire stores and they can order em(tuff country possibly) the 4" dropped ford arm will give pplenty of clearance
  14. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    Im the one that used the ford van pitman arm.. Thatsw my site that BadDog pulled the link off. It bolts right up and the castle nut clears it completely (even with the 3/4" steel plate that a previous owner used to fix the cracked frame with). I wouldnt go with anything less than that and they can be had at a junk yard for around $5. Cant beat that. Not even by making your own.
    '78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt rear w/ Detroit
    <A target="_blank" HREF=http://65.11.18.114>http://65.11.18.114</A>
  15. Cliffy
    Oct 8, 2000
    99
    I tried getting that part and it's a tough one to find, I found it for Ten dollars.
    On the other hand I talked to parts mike about the other two Pitman arms (the FS Jeep one, and the 70 F250 one) He told me that They were both the same part as far as he's concerned. IE: same part #'s
    Just an FYI, I oredered mine yesterday.
