crossover steering
Discussion in 'OffRoad Design' started by badger red, Jun 4, 2005.
  1. badger red
    badger red 1/2 ton status
    Jul 30, 2004
    208
    south central KS
    Is there a minimum amount of suspension lift required (for clearance purposes) to use the ORD crossover steering for either the dana44 or dana60?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    It starts getting tough to fit all the parts below about a 3" lift. And really below that height the factory steering works pretty well for the uses that a 3" lifted full size will serve.
    Are you looking to go lower than that? It's possible, just not as easy.
  3. badger red
    Jul 30, 2004
    208
    south central KS
    Stephen--thanks for the info. I was planning on a 4" lift, no more than that, as I don't want to get too high--I'll cut sheetmetal if necessary. I checked the ORD website and didn't see a minimum lift dimension in the crossover steering section (hope I didn't overlook it!).
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    It might not say on the site, but there's very limited demand for crossover with less than a 4". So in your case, no problems. In fact, the majority of our kits are with 4-6" lifts.
