Crossover steering
Discussion in 'The Garage' started by DragonsBane, Aug 2, 2006.
  1. DragonsBane
    DragonsBane Registered Member
    Dec 28, 2005
    47
    Clifton, AZ
    I lookedat the tech section for the crossover steering mod, but my K10 has a crossmember in the front that looks nothing like one in the tech article. It looks more like an upside down U. Will I be able to do the crossover without modifying it? I'll have to find my digi camera and see if I can get a pick up.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You will be fine as long as you have enough lift. Usually 4" or more.
    That is the stock crossmember.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    The tech article uses a straight draglink. You will have to use the bent style offered by everybody that makes x-over stuff, and you'll be fine with the stock engine crossmember.
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Yup! I have the WFO x-over draglink and it works great with my 52" front
  5. DragonsBane
    Dec 28, 2005
    47
    Clifton, AZ
    good deal. I was planning on using the 56" rears I have up front, hence the need for crossover steering. I have a set of 64" for the rear but not sure if I want to swap the in. Might just stick with the 56" rears and do a shackle flip. I'm looking for 4-6" of lift overall. And since I'm getting a little bit of body cancer I am going to trim the fenders a little. Thanks all.
