Crossover Steering ?
Discussion in 'The Garage' started by 73K5Kid, Nov 2, 2006.
  1. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
    I don't quite understand what I will need for crossover. I have looked at the kit from ORD. I know I will need a 2wd box. If you can tell form my pic will I have to do anything else like machining or draglink or.......
  2. 73K5Kid
    Sep 24, 2002
    583
    chandler az
    Not a very good pic sorry. :o
    c7_1.jpe
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
  4. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    I'm no expert, but i can tell you what i did. I just completed it last weekend.
    I bought a D44 - 8 lug running gear. I removed the knuckles and had MuddyTaz drill and tap the passenger side to match the drivers side. I then bought sky mfg arm and stud kit. I assembled the componets and bought a sky mfg tie rod. That was just the beginning. From there i went to the wrecking yard and bought a 2WD steering box from a 1978 suburban. I also grabbed a pitman from a 1978 bronco, but i felt it was to whimpy so i bought an aftermarket trailmaster ford drop pitman arm. I then didn't like the steering shaft so i replaced it with a 1991 jeep cherokee steering shaft. I did extra work to it so i had splines on both ends. Anyway below is the final working componets.
  5. 73K5Kid
    Sep 24, 2002
    583
    chandler az
    That is what I thought. I cannot just buy a kit that can bolt right in. I may have to drill knuckles. I may need to use pitman arms from other vehicles etc etc etc. Is there a kit you can buy that is for my year of axles and my k5? I was hoping I did not have to hit the junkyards and order other kits. :doah:
  6. 73K5Kid
    Sep 24, 2002
    583
    chandler az
  7. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    ORD is a complete kit without the knuckle. you want your knuckles to match. unless you are going complete hi-steer. the angles/lengths of the tierod mount can vary between knuckles. this will have an effect on your steering. get the part number from the knuckle they will send you. it should be one number off from your driver side knuckle.
  8. draggbody
    draggbody 1/2 ton status
    Jul 13, 2005
    282
    columbus GA
  9. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    You can still use your existing 4wd steering box if you're doing regular crossover or high steer... you only need the 2wd steering box when you're going hydro assist or full hydro
  10. 73K5Kid
    Sep 24, 2002
    583
    chandler az
    I would like to do this as cheap as possible. If I do not have to change to a 2wd box that is even better. I am not going to do hydro. I would like to get rid of the k5 pulling to the right when I am zooming down the freeway with an 8in lift. It will be a part time daily driver and a light wheeler. What is the cheapest and easiest way :confused:
  11. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    regular crossover would be the way to go... what axle do you have now?
  12. 73K5Kid
    Sep 24, 2002
    583
    chandler az
    dana 44
  13. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    then you're good to go... dana 44 already have the flat tops on the knuckles so just call up ORD or WFO concepts and they ll hook you up with a pitman arm, draglink and steering arm... thats it!
  14. makovai
    Jun 6, 2006
    854
    oregon city
    If the price is right, to me that looks like a good kit. I spent little over $200 for the daglink and steer arm with studkit. Then $70 for the pitman arm, $40 for the knuckle prep, $8 for the steering box, $5 for the jeep steer shaft. So i prolly have about $350 into mine.
  15. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    HUH? how do you get around the shaft difference?
  16. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    Not all dana 44's had flattops on both sides. even if they did he would still have to get machine work done. its more then just drilling holes and tapping them. the passenger side is rough and at least a 16th high.
  17. 73K5Kid
    Sep 24, 2002
    583
    chandler az
    Thanks I like this route.
  18. 73K5Kid
    Sep 24, 2002
    583
    chandler az
    Not all dana 44's had flattops on both sides. even if they did he would still have to get machine work done. its more then just drilling holes and tapping them. the paasenger side is rough and at least a 16th high.
    I can tell this is going to be fun. LOL
  19. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    how so,
    one box opperates side to side, other is front to back
    only option to retain the factory box and have cross over the passanger knuckle is to swap sector shafts, or use a custo or resplined pitman arm.
  20. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    I know....thats why I said what you quoted me.... In a later post, I said ORD or WFO or any other place will include a pitman arm in their crossover kit that works side to side instead of front to rear.
