Crossover steering
Discussion in 'The Garage' started by GRIZZZ, Mar 15, 2007.
  1. GRIZZZ
    GRIZZZ Newbie
    Feb 8, 2006
    4
    Calgary Alberta Canada
    Hey,
    I was just wondering if the steering knuckles from a dana 44 and gm 10 bolt are interchangable without any problems. I was going to swap knuckles to make X-over steering.
  2. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    They are the same.
  3. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    You might have to swap spindles as well, but it just depends.
  4. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    If he's reusing all the same parts, and just changing knuckles, theres no issues with spindles. the ONLY thing you run into is a difference in where the tie-rod attaches
    on 10bolt knuckles, the tie-rod attaches from the bottom of the steering arm, on flat tops, it's from above. If you're going to run a tie-rod in the stock location with flat top knuckles, it sits REAL close to the leaf springs. so close you have to put the tie-rod ends into the knuckles, then thread the center piece into them. No room to put the whole assembly in in one piece!
