crossover steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ducati-cooter, Jan 26, 2002.
  1. ducati-cooter
    ducati-cooter Registered Member
    Jan 24, 2002
    78
    Madison WI
    I am wondering if anyone makes a crossover steering system for a 10 bolt axle. I would get a D60 or a D44 but I don't have any real good places to go wheeling here in Madison WI. Any help would be appreciated.
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    to do a crossover on a ten bolt you need to find a passenger D44 nuckle with the flat top...and have it drilled out and taped for studs...then you are sent to go..hope this helps
    <font color=green>Chaz</font color=green>
    [​IMG]<a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>[​IMG]
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Offroad design can sell you everything you need but I think you still have to find the flattop knuckles(pretty sure you need both so they will match???)
    formerly 77chev
    still a jerk though
  4. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    or take a cheeper route. get the crossover done to your tie rod. your tie rod has a hole in it for your steering stableizer. flip your tie rod so you have that hole on the passengers side. you get that hole tappered the size of a tie rod end. you now connect a rod from the pitman arm to that tie rod you just machined. This is sort of how some fords have their steering systems.
