Crossover steering
Discussion in 'OffRoad Design' started by BI U JIMMY, Dec 14, 2000.
  1. BI U JIMMY
    BI U JIMMY Registered Member
    May 20, 2000
    74
    Stephen, first let me compliment you on some outstanding products. I have a several of your products and could not be happier. I revisited your site and saw that you mentioned a crossover steering system that you were working on and I am very interested in it. Could you give me some info on what are the costs and what you provide. I look forward to hearing about this, thank you
    Jeff
  2. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    I to am interested in this. More info please.
    [​IMG] I have to agree with the Puddy Cat. [​IMG]
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Ok, here's what we have.
    Right side steering arm $150 (tapered for big GM tie rod end)
    Install kit for right side arm $30 (studs, cone adapters, lock nuts)
    Pitman arm $70 (tapered for big GM tie rod end)
    Machine work on your right side knuckle $70 (mill flat and drill and tap)we can't sell knuckles outright, we don't have enough of them or a steady supply, so we have to have you send yours in.
    That's about it for now, we're looking at carrying AGR boxes and pumps, may or may not do that, and we're looking into building draglinks. It's not that hard, we're just not sure how to go about the measure and communicating process. Basically just need a form for it. And need to set up in the shop to handle it!
    There are some other details that go with lift height etc that would be easier to go over on the phone on an individual basis, but this will work with anything from a 4" lift to a 8" really easy, higher lifts with some mods.
    SW-ORD
  4. CK5
    May 19, 1999
    21,622
    701
    CO
    Any Dana 60 x-over stuff?
    Steve
    1990 K5 with stuff
  5. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    Dana 60 and keeping the sway bar with 6" lift max?
    <font color=green>Joe Angelicchio
    86 Jimmy 4+3, 35-&gt;39.5 tires,4spd
    </font color=green>
  6. azjimmy
    azjimmy Registered Member
    Sep 22, 2000
    80
    Battle Creek, Mi.
    So the Dana 44 stuff is already available? And what kind of turn around time on the knuckle? Pat
    <font color=red>Don't sweat the small stuff, and it's all small stuff!</font color=red>[​IMG]
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We're working out details on the D60 right now. Thrashed around with someone else's right side arm last friday, ended up changing it pretty drastically to make it work. But it does work now. Put about 550 miles on it this weekend. No set date on having the D60 xover ready, but we're working on it.
    Turn around on the knuckle is about a week to 10 days. really it only takes a couple hours to do it, but it's nice to do more than one at a time, and we have to schedule it in, so to be safe, i'll go with the long estimate.
    SW-ORD
  8. clintsk5
    clintsk5 1/2 ton status
    Mar 2, 2000
    288
    Kingman, Az.
    How about a package deal on all the work on the crossover steering?( including all parts you had listed and machine work )??...we send you a knuckle...you do it up!!!..What else is needed to complete the project???...Thanks for your time!!!!!
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Does this kit allow you to retain the original 4x4 steering box?
  10. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    No, you have to replace it with a 2wd unit. You can usually pick them up at a junkyard for $40 or so.
    Communication Breakdown
    74 Blazer
    Zeppelin
  11. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Can I re-drill the passenger side steering arm so it isnt tapered? I want to use heim joints instead of tie rod ends.</font color=blue>
  12. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I'll try to get a couple of answers in one post here, One is on the swaybar with xover. Basically, it's pretty hard to make it work. I don't think it's possible while retaining the ability to disconnect it.
    You can drill our arms out for a 3/4" bolt. No problem.
    Total cost for a package is yet to be determined, but with the machining, I'm betting on it being about $500 to $550. The draglink is the big variable right now.
    SW-ORD
  13. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    CAN OR WILL YOU GUYS SELL PARTS OF THIS KIT SEPERATLY?ID LIKE TO GET THE PITMAN ARM THATS ALREADY DRILLED AND TAPER REAMED FOR THE CORRECT TIE ROD END.AND IF YOU GUYS WORK OUT THE DETAILS ON THE DRAG LINK ID LIKE TO GET THAT ALSO?THANKS FOR YOUR TIME.
  14. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We sell all the parts separately, no prob. Still working on the draglink, it's a little ways out.
    SW-ORD
