crossover steering
Discussion in 'The Garage' started by uao85, Feb 10, 2004.
  1. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    Is anyone out there running a crossover setup on a 10 bolt? I have the later model 30 spline axles and wanted to keep the front end since a dana 60 really isnt in my budget. I have heard of people using dana 44 knuckles, but would you be able to use dana 60 knuckles? because most of them have the flat top design and I thought I would be able to do my 8 lug conversion at the same time. And has anyone ever heard of machining the passenger side 10 bolt knuckle to a flat top design? I was told you could have the passenger knuckle machined, but Im not too sure about that. Well any feedback or information would be awesome and greatly appreciated. /forums/images/graemlins/thumb.gif
    Sincerely
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    You can't machine a 10 bolt knuckle. The knuckle has to have a flat top to begin with 10 bolts don't. Dana 44 and 10 bolt are identical from the knuckle out. Find a pre 77 3/4 ton Dana 44 and take everything from the knuckles out. It will all just bolt up to your 10 bolt. /forums/images/graemlins/thumb.gif
    Check out ORD crossover kits
    Don't think you could put 60 knuckles on a 10 bolt cause 60's have kingpins and 44/10B have balljoints two totally different designs.
  3. uao85
    Jan 2, 2004
    1,867
    Edge of insanity
    thanks for the info /forums/images/graemlins/thumb.gif
    Remington
