crossover stupid question...
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JohnSPledg, Feb 26, 2003.
  1. JohnSPledg
    JohnSPledg 1/2 ton status
    Feb 22, 2001
    141
    Baton Rouge, La
    Here is a stupid question. On the 2wd steering box, does it need to be 67-72 or will later models fit. I never bothered to think about it before, and I am trying to stock pile my parts.
  2. 6869704x4
    6869704x4 Registered Member
    Aug 1, 2002
    42
    NW Fla
    Yes but,
    Newer boxes will work. But sometime in the 80s(I think) the lines changed from flare to O-ring. If you get one of those you will have to get a newer pump with O-ring fittings or I think you might could change the adapter on the pump. Not sure about that because I didnt try it but I know it is threaded into the pump.
    You could splice a union into the metal line to change from O-ring at the box to flare at the pump. No problem if you have a flaring tool. But thats two more places for leaks.
    I found a 71 GMC and grabbed the box out of it. I could have just swapped the sector shaft(the easiest option by far) but one of the holes in my 4x4 box was stripped so I swapped the whole thing. Thats another thing. The sector shaft out of the newer box wouldnt work in my older 4x4 box but the older 2x4 one would have. When I held them up next to each other I could see why.
    PS What parts do you have so far?
  3. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    As above, but you can also have custom hoses made. A lot of larger parts store now can even do it while you wait.
  4. JohnSPledg
    Feb 22, 2001
    141
    Baton Rouge, La
    Thanks for the help, i think I know where I can score a nos 2wd sector shaft. Will newer gear boxes bolt up to the frame though, my 2wd truck has armstrong steering and its a lot easier to find a 73-87 truck in the yards than a 67-72.
  5. 6869704x4
    Aug 1, 2002
    42
    NW Fla
    I know a mid 80s burb 4x2 box bolted to a 70 4x4 frame.
